Error Messages: Service AdvanceTrack/ Hill Descent Control Fault
3 visits to dealer, still having issue
I've been having issue where I get a chime (double ding) and no lights. Then I get the same chime (double ding) and traction control light comes on. This gets progressively worse until I start getting Hill Descent Control Fault, Service Advancetrack on my dash. Then it starts cycling Hill Descent Fault, Service Brakes, Advancetrack and the infamous Wrench comes on. Meanwhile, all 3 idiot lights light up on the dash (Traction Control, ABS, Emergency Brake).
Someone made mention about hauling a trailer when his started. Thinking back, mine started with this as well. I was hauling a trailer when I first experienced this. I got horrible mileage that trip too. It's been happening ever since with/without a trailer in tow. I haven't felt any hard pulls to the left or right as others have mentioned.
Dealer keeps finding different connectors between computers that have corrosion in them. They clean them, lube them and still same. They claim they have driven and can't get any alarms, but see them in the diagnostics. I drive for about 10 minutes and get at least 1 alarm if not more. It seems to happen whenever I start hitting rough patches in the road. There is a section of road that I can drive and it seems to almost always come on when driving over that.
I'm thinking rear wheel sensor, but dealer says no. It snowed here couple of days ago and initially I wasn't getting the Traction LED light on the dash. (same one as usually comes on with a fault) I intentionally spun the rear wheels a couple of times and then the light came on.
Don't know how a 7-way correlates to any of this, but these damn things keep getting more and more complicated. What ever happened to KISS (Keep it simple stupid?) So, we drive vehicles today that have more computing power than Apollo 11.
its a large grey plug that is mounted to the top of the e brake bracket. Only large plug up there. Squeeze the plug together, make sure all the wires are pushed into the plugs. This fixed mine. Happens all the time with people who regularly apply their park brake.
Just to add a little....
Can cut its e-brake bracket wire tie off, then wire tie it out of the way off the e-brake vibrations.
If you lightly kick the side panel or snap the e-brake off/on again, then it will usually go off temporarily. The fix will last longer if you unplug/reseat the plug with a small bit of elec lube spray,,, but till you tie that large plug off the e-bracket its all temporary..Since I did that years ago, never even 1 more adv trac, etc, warnings.
jmo
Correct.
jmo
jmo
so I unplugged checked and replugged and still the warnings. Then on top of it an hour later on the way home it popped another .... check brake system and the ebrake light ....so it’s now Service Advancetrac ..Hill Descent Fault ....Check Brake System. ... ABS light and EBrake light ....sigh.
Make sure you got the right plug, cut its wire tie free from the e-brake bracket like in my above post, then pull apart and check all the pins are seated fully and then fully engaged when plugged together.
I had this same exact trouble a few years ago while on vacation. Dealer had a look and it was this plug. Have not had any trouble of this kind since. Dealer re-set the plug and all was good.
Some of the cheaper OBDII Code Readers can cause this trouble too, I've read. If you have one plugged in, take it out and see if the code re-appears once it's reset.
bruce...
bruce...
bruce...
bruce...
Is this plug the one circled in red or green ? If it’s the green I can’t get the plug free from the bracket .... there’s a tab of some sort and I have pulled till I almost popped a blood vessel lol. Do I break off that tab ? How do I undo the plug ? Squeeze ? clips ? Sorry it’s hard to see what’s what up in there.
The following users liked this post:
#29
Just bought a 2016 f350 from a private seller 35k miles. Having the Service AdvanceTrack/ Hill Descent Control Fault error with check brake light on. Vehicle power down to only run up to 3rd gear, high rpms. Warranty almost up, taken to LHM ford here in SLC. I wonder if there are any new updates to fix. Trying to avoid a costly repair if its a speed sensor, ABS monitor, ECM module, or ebrake connector if its gone bad before warranty expires. Is anyone still having issues?? Ford service seem to be in the dark on this issue after reading comments, and taking it in. Any help from the community would be greatly appreciated.,
#30
Mine still throws the advance track and hill descent alerts up now and then, but it's more of a minor annoyance than an issue for me. When I get around to it, I will mess with the plug at the parking brake and get it to clear for several months. I'm right at 100k and first had the issue around 20k.
