Starter Relay Issue---1986 F150 300 V6 - Ford Truck Enthusiasts Forums
Old 04-24-2017, 07:32 AM
stpaulf150
stpaulf150 is offline
stpaulf150 is starting off with a positive reputation.
Hey everyone, I've been having a starter solenoid issue on my 86 F150 300 V6 for the past few weeks. Every 2-3 starts, the solenoid will get stuck in the closed position and the starter won't kick off when I start the truck. I have replaced the solenoid, the starter, all battery cables, and have checked that all connections and grounds are free of rust and corrosion. Still happens, especially when hot. Where else should I be looking? Is a surge of power making the solenoid stick? Ignition switch? Thanks for your help, this is driving me nuts.
Old 04-24-2017, 08:23 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.
First, welcome to FTE!
High current is what usually welds a solenoid's contacts shut. A tight engine can cause high current to the starter, or advanced timing can as well. And, low battery voltage can cause higher than normal current.
So, is the engine new? (By the way, are you sure it is a 300 V6? The 300 is an I6)
Old 04-24-2017, 08:28 AM
stpaulf150
Hey Gary, thanks for the welcome! Excited to be here with a gang much more experienced than I am.
You're right. The engine is the I6, not V6.
I checked the battery voltage and it's reading fine, although I do know that the current battery (replaced by previous owner) is technically too small for the truck. It's basically a Honda Civic battery, which has worked fine up to this point. Could that lead to this happening?
What's a tight engine refer to?
Thanks again, I really appreciate the help troubleshooting this. I bought this truck basically so that I could learn how to fix it, and I'm really enjoying the process.
Old 04-24-2017, 09:10 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I wouldn't have thought a smaller battery would cause that problem, but maybe. However, if you are going to replace it now would be the time.
What brand solenoids are you using? It is possible to get bad ones, and some have gotten multiple bad ones. Or maybe weak ones. The Motorcraft ones, even from a salvage, are preferred. Or, NAPA ones are said to be better.
A tight engine refers to one with tighter-than-normal clearances internally, like main and rod bearings. When warm the clearances are reduced, and that makes the engine hard to turn over, which pulls a lot of current through the solenoid. Tight engines have usually recently been rebuilt and the clearances tend to get larger with use.
Old 04-24-2017, 09:11 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Old 04-24-2017, 09:20 AM
1986F150six
1986F150six is online now
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
stpaulf150, welcome to the forum!
As Gary said, it is not at all uncommon for the "cheapo" new relays to fail, sometimes on the first try. If you decide to go with Napa, be sure to tell them you want the "real" NAPA [normally Echelin] part. In order to better compete with all the other "box" stores, Napa has an inexpensive line as well as their better stuff.
If you have a friend who has a Ford truck, van or passenger car of the same era, ask if you can swap the part and see if that fixes your problem. If it does, plan to pay ~$35 for the Motorcraft of Napa part. Stay away from the $15.00 ones.
Old 04-24-2017, 11:29 AM
kr98664
kr98664 is online now
kr98664 has a very good reputation on FTE.kr98664 has a very good reputation on FTE.kr98664 has a very good reputation on FTE.kr98664 has a very good reputation on FTE.
You might find this long-winded thread to be of some interest. The original poster had a similar situation as you. The eventual fix was to get a genuine MotorCraft relay:
https://www.ford-trucks.com/forums/1...solenoids.html
Old 04-25-2017, 06:28 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.
When it happens again pull off the small wire from the solenoid.
If it stops then the IGN switch is sticking and needs to be looked at.
May not hurt to check into it anyway. Pull the switch and clean it as it must need cleaning after all the years and adjust it.
Dave ----
Old 04-26-2017, 05:27 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Another option is to use a PMGR starter and rewire slightly to significantly reduce the load on the starter relay, aka "solenoid". See here: PMGR Starter Wiring - ???Gary's Garagemahal
Old 04-29-2017, 02:33 PM
stpaulf150
Thanks for all the ideas everyone---
The current solenoid is a cheapo from O'Reilly's, so I'm ordering a Motorcraft solenoid from Summit racing to see if that can solve it. I'll keep ya'll posted.
Interestingly, I read elsewhere that someone used an Accel heavy duty motorcycle solenoid that fixed a similar issue. Anyone heard of this before?
cadunkle
23
03-14-2018 01:21 PM
Michael Schneider
1997 - 2003 F150
24
01-28-2018 11:47 AM
Glaser67
10-21-2017 10:04 AM
Lauraroka
04-18-2017 06:41 PM
fordatic
09-23-2016 01:28 PM
Quick Reply: Starter Relay Issue---1986 F150 300 V6
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
