Airlift Airbag compressor
Hi all,
I just installed an airlift brand compressor to pump up the airbags on my 2005 V10 Excursion Limited. I installed it in the little cubby hole that the jack is installed in. I still have to connect the power supply. I thought of tapping into the cigar lighter style power supply already back there but it has power all the time. Any ideas of a good power source to tap into? I can run the wires to the fuse panel but not sure which one to tap and which side is the power source side of the fuse. Thanks for any help!
It comes with a 15 amp fuse.
If I do this and forget to turn the switch off, will the air pressure monitoring system drain my battery when the truck is not running? I know that the compressor would if it sensed the need for air and turned on.
If you did the Wireless One, the manifold controls when the compressor kicks on...power that AND the compressor all the time, it can fill up even when the key is off.
If you just did a compressor that has the pump on switch and a gauge, then you'd have to press the button manually to kick on the compressor...so you SHOULD be OK.
Best option is always to install a power cutoff switch...you never know when something could short out or have an issue.
Thanks for the info. Yes it is the wireless one. I like the idea of killing the power. Technically, I only need it when towing my camper so disabling it when it is not needed is a good thing. I only worry about forgetting to kill the power to it when I shut the truck off say over night. I know that if the compressor runs it will drain my battery when the ignition is off.
Does anyone know if the pressure monitor draws a lot of power? I really appreciate any help on this. Thank you.
myf16n
11-26-2018 08:14 AM
wally_games
1999 to 2016 Super Duty
04-11-2018 05:57 AM
cedman
20
09-02-2015 06:31 PM
