Switching out Signal Stat #902 SigFlare
The PO of my 1960 F100 had a Signal Stat #902 SigFlare that did not work I removed it and tried to repair it. (See photo)
Here's the original Signal Stat #902 SigFlare that did not work
Couldn't get the original to work so I bought a new turn signal switch (See photo).
New Signal - 7 wires
Here's the problem the original had 6 wires and the new has 7 wires. Does anyone know how I can wire this to work in my truck? Thanks!
Hey thanks everyone for all your help!
As it turns out, I was able to repair the original Signal Stat #902 SigFlare. It worked fine when I bench tested it and hope to install it tomorrow as I finish the re-wiring my truck.
My repaired Signal Stat #902 SigFlare
Bench tested
Bench tested
1961/66: 4 way flasher switch (if present) located on the dash to the right of the steering column.
1967/69: 4 way flasher switch located on the inside of the glove box.
1970/72: 4 way flasher switch located on the dash to the right of the steering column.
1961 was the first year that Ford offered 4 way flashers, optional thru 1966.
Highwayman7043
05-29-2018 08:24 PM
Nicholas+
03-13-2016 04:39 PM
das54
01-04-2016 06:28 AM
79F250isalive!
03-01-2015 06:15 PM
GeneStoner
04-25-2004 08:03 PM
