Clearance and marker lights for the copper truck
Old 04-23-2017, 06:05 PM
PapaBearYuma's Avatar
PapaBearYuma
PapaBearYuma is offline
Since I was at a standstill on the intake manifold project, I decided to go ahead with the cab marker/clearance lamps...
  • Pulled the left side headliner moldings
  • Lowered the right side headliner moldings
  • Pulled the headliner
  • Removed the hold-down bolts and had the kids help me remove the shell
  • Marked out the drill holes for the lamps
  • Drilled out the holes-all fifteen of them
  • Mounted the LEDs in the sockets, mounted the sockets in the bases, mounted the bases to the roof
  • Soldered-up the hot leads to a red wire
  • Soldered up the grounds to a black wire
  • Pulled the dash bezel and instrument cluster
  • Snaked the hot and ground leads down the A pillar
  • Tied the hot lead into the brown for the external lights
  • Put a loop connector on the ground lead, and screwed it to ground
  • Discovered that LEDs really are polarized, and had to fix three of them
  • Discovered one LED was broken, so off to O'Reilly for a pair
  • Discovered the socket had a bad connection, so repaired that
And...they all light up!
Link to the marker lights:
5x Amber Roof Cab marker Running Cover LED Light Lamp T10 Switch Kit for Ford | eBay
Clearance lights for the 79 with a lot of pictures:
https://www.ford-trucks.com/forums/1...nce-lamps.html
Old 04-23-2017, 06:23 PM
Broncodude646's Avatar
Broncodude646
Broncodude646 is offline
Looking good. Cab lights belong on these trucks as far as I am concerned!
Old 04-23-2017, 06:32 PM
PapaBearYuma
Thanks! Now I'm gonna have to get them lined-up for a new portrait...
PapaBearYuma
16
04-01-2017 11:17 PM
fordguy2236
1997 - 2003 F150
05-19-2014 10:37 PM
fordka
09-04-2012 09:22 PM
morganburger
08-25-2003 06:02 PM
sleet_tech
01-04-2003 01:43 PM
Quick Reply: Clearance and marker lights for the copper truck
