9.75" 3.73 rear axle rebuild
Old 04-23-2017, 09:53 AM
robbv's Avatar
robbv
robbv is offline
has anyone had any success rebuilding there rear diff?
i will be doing everything ideally all bearings axle shafts if there heat damaged new gears replace the clutch packs and crush sleeve
my bearings are going on my pinion shaft causing my reared backlash or slop in the ring and pinion to become excessive
anyone have any insight in to this before i tear it down would be sweet
Old 04-23-2017, 11:06 AM
meborder's Avatar
meborder
meborder is offline
Posted a copy in the clutch, differential, and transmission ECT. Forum for another set of eyes
Old 04-24-2017, 11:40 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
Unless you want a new hobby, have someone experienced in setting up this axle do the job. There are threads with DIY axle set up, and some of those come back complaining about a whine.
Differential set up is in the 8 to 9 range on a scale of 10 for automotive repair.
Especially an integral axle where you are going to be doing this on the ground (probably) or having to take the whole housing out of the truck.
Call me silly.
robbv
2009 - 2014 F150
04-23-2017 09:53 AM
serviceguy
02-01-2010 07:15 AM
sonsila
01-20-2009 12:20 PM
Born-n-raisedFord
12-28-2003 07:32 PM
Quick Reply: 9.75" 3.73 rear axle rebuild
