Curt hitch and factory prep
Installed a Curt Q25 in my F-350 today that has the factory bed prep. For those that have done this, how hard was it to turn the latches on your hitch to lock into the prep? I adjusted like the instructions said and after finishing putting the hitch together I set back in the holes. Instructions say that you shouldn't have to force handles to turn. 1 handle on each side seems to fit like instruction calls for, light pressure to turn. The other handle on each side barely requires any pressure to turn. If I adjust the bolt to the next hole, I would have to force the handle in. Is it normal for the handle to be "easy" to turn in?
I have adjusted all bolts with the cotter pin out too, but still with same results. Talked to Curt and they said what it is doing is normal. They did say the main thing was not to force as it will damage the locking device. Will find out Sunday with first tow of fiver on my trip to Pigeon Forge.
ritterjd
Fifth Wheel & Gooseneck RV Towing
11-17-2016 04:59 AM
Chalkie
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-04-2013 07:53 PM
