88 302 Cranking: Not starting
Help! No previous problems. Van set for a week. Quickly starting as usual. Ran for about 3 seconds. Died. Cranks, but does not start. Hear fuel pump when key is on. Computer(EEC-IV) gives code 33 error only. Voltage at spark plugs. Sprayed starting fluid. Cranks, but does not start. Any help? Thanks.
Code 33 is an Egr related problem . I dont think that will cause a no start unless its stuck completely open & even then the engine would try to run . Check & make sure you have the proper fuel pressure . If thats ok then there may be a mechanical problem , timing chain for instance .... How many miles on this vehicle ?
r_paetzold
02-08-2013 02:53 AM
Edgewood
06-26-2009 08:53 PM
raceopticsbus
18
02-13-2007 06:26 PM
