Am I reading this timing pointer right?
Old Apr 22, 2017 | 04:55 PM
xjpilot's Avatar
xjpilot
Originally Posted by reamer
40? You must be off a tooth on the dizzy gear....
Thats always a possibility, it was my first time ever installing one.
Old Apr 22, 2017 | 05:01 PM
reamer's Avatar
reamer
At TDC on #1 you "should" be at 0 degrees on the edge where CountryBumkin showed ya
(make sure you are not on the Exhaust stroke).......
Old Apr 22, 2017 | 05:09 PM
xjpilot's Avatar
xjpilot
When #1 is at TDC, does it matter what tooth the distributor goes in on, as long as its pointing to the #1 wire when it goes in?
FuzzFace2's Avatar
FuzzFace2
Even being a tooth off you should be able to get it timed right if you can turn the dist. enough.
You can have the dist. in 180* off and still get it timed.
The OP needs to check where TDC is then he can find a timing mark that works.
or
Why not set timing with a vacuum gauge?
Dave ----
Old Apr 22, 2017 | 05:18 PM
CountryBumkin's Avatar
CountryBumkin
Originally Posted by xjpilot
I thought of that too when I started to think about it. Now to figure out how to make the motor run, since apparently it really likes 40 degrees initial
That looks like an aftermarket distributor (MSD?). See if the mechanical advance (weights) are frozen or if advance spring(s) have come off.
Is the 40 degrees you refer to at the Orange line?
Old Apr 22, 2017 | 05:22 PM
reamer's Avatar
reamer
IF you are on TDC, and take the cap off it should be pointing at #1 as indicated ON the cap.
If not, you can pull the dizzy, rotate the pointer, but not onto #1, 302's and 351's rotate counterclockwise, so before pulling, put a mark on the body where the rotor is.
Then when you pull the dizzy, mark where the rotor ends up, now you can see how far off #1 indicator you need to place the rotor to install the Dizzy. If done correctly the rotor will end up on #1
Old Apr 22, 2017 | 05:25 PM
xjpilot's Avatar
xjpilot
its a brand new summit distributor I installed yesterday, and definitly wasn't frozen at all. the truck runs great when 14-16 is on the orange line, but if I'm reading the pointer incorrectly, than that is closer to 35-40 degrees on the correct part.
It appears that all i need to do is set TDC and check the balancer, and I'd venture to guess that 0 will be somewhere near that orange line.
I've never set timing with a vacuum gauge, so I'll have to look in to that
Old Apr 22, 2017 | 05:29 PM
xjpilot's Avatar
xjpilot
When I installed it yesterday that's what I did. However, today when I went to set timing the vacuum canister was pointing to where it wouldn't be very adjustable, so I removed the whole assembly, and rotated the whole assembly maybe 1 tooth till it slide in without having to adjust anything
Old Apr 22, 2017 | 05:31 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The timing marks on the crank don't matter whether exhaust or compression.
TDC IS TDC.
He is only trying to tell that the balancer marks are in phase with crank throw.
It also doesn't matter where he stabs the dizzy.
the inductive light is picking up the spark... and the spark has to be relative to the crank throw.
​​​​​​​It just comes half as often.
As long as he has #1 wire, THAT is where the ignition is being triggered.
Old Apr 22, 2017 | 05:33 PM
CountryBumkin
Is it possible that someone ( a previous owner) installed a different timing pointer assembly? Also, as mentioned the timing marks on the damper could have slipped. If they did that would mean the damper is bad (the rubber material between the inner damper and outer has failed). The best way to figure out what is going on is to order a "piston stop" tool from summit. That tool is used to find exact TDC.
Old Apr 22, 2017 | 05:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can also just shift every wire over one position the distributor.
360° ÷ 8 = 45° which is about what you say you are off.
Old Apr 22, 2017 | 05:35 PM
xjpilot's Avatar
xjpilot
360° ÷ 8 = 40° which is what you say you are off.
thats a very good point. Maybe I'll try that tonight when I get home
Old Apr 22, 2017 | 05:39 PM
  #28
reamer's Avatar
reamer
If it is firing #1 on the exhaust stroke, that's a backfire through the carb?
TDC IS TDC.
Old Apr 22, 2017 | 05:50 PM
  #29
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It is not 180° out.
He said it runs well at 35-40°, which means the damper has slipped or the pointer is wrong for his damper.
I asked him to check tdc #1 against the damper marks. Which are *attached to the snout of the crank*.
Cam position has nothing to do with it.
​​​​​​​If it was firing on the exhaust stroke, it would fire out the open exhaust valve.
Old Apr 23, 2017 | 12:48 AM
  #30
Ken Blythen's Avatar
Ken Blythen
Originally Posted by CountryBumkin
Is the stock location for alternator? Did this truck get the alternator mod?
It looks like it is mounted where the air pump would go - and it should be in the upper location on that bracket (heater hose would, of course, not be coming out of bracket hole).
I don't know - I haven't seen everything.
That mount bracket & hose position are both correct; the deleted air pump sat in the upper lugs on the bracket, with a belt from the second groove on the alternator pulley.........my '83 was originally identical, but while de-smogging I removed the air pump, & trimmed the lugs off.
