Four pin flat, five pin flat, six round and now seven round connector
Can somebody help me understand these.....like the timeline?
Okay the four pin flat has been around forever...I got that. Ground running lights brakes and turn signals.
What is the five pin flat? If it is more modern then why does my 2015 F350 have the four pin flat? What does the five pin flat do?
Okay then we have a six round that I presume was around before the seven pin round?
On the seven round does your trailer have back up lights?
There is a good chart on this page that describes what features every connector includes.
https://www.etrailer.com/faq-wiring.aspx
The 5 pin flat includes a pin for trailer brake lock out solenoid. For example, a boat trailer will often have surge brakes that engage when you go to back up, so an electrical solenoid may be incorporated to prevent the master cylinder from being engaged. Otherwise you'll have to get out and insert a lock out pin or similar before backing.
The six pin round is typically used on trailers that do not have a battery/charger circuit, but do have electric brakes - such as horse trailers.
The seven pin rounds are used on trailers that do have on board battery/charger, such as travel trailers, etc.
I'd say the appearance of each of those connectors is in that order as well, since they are developed to support the growing needs of whatever is being pulled.
Well, they are. The brake lights are usually brown wire, left turn yellow, right turn green. The back up wire is used to activate the surge brake lock out solenoid.
The four pin flat also will support brake, left turn, and right turn, using the same color wires as the five pin.
In a nutshell:
4 flat. Standard for small trailers, and boats. Most common
5 flat. Kinda an oddball, never made it's place or mark. Very rare to see.
6 round. Heavy duty metal plug. Common on farm and construction equipment and other heavy duty harsh environment applications.
7 blade round. Standard RV plug. Also seen on gooseneck flatbeds.
7 pin round. This is a semi truck and trailer plug. Only mentioning so you don't grab one by mistake at a truck stop.
By far the two most common and most used are the 4 flat and 7 round (blade). Just about anything you buy will have one of the two. Most vehicle towing packages come with a 4/7 combo.
I have had issues on my semi with that plug too. Not breaking but not making good connection, lights flashing on trailer going down the road.
Link to E-trailer plugs. I see Pollak also makes a metal one if you want to go that way https://www.etrailer.com/s.aspx?qry=...tor-pc-7_Blade
I Have also used the metal ones and never had any issues either but all I have used is Pollak.
Dave ----
Dave ----
In a nutshell:
