brake hose - oem again or upgrade to SS braided?
Hey all thinking of redoing brakes all around and thinking I might as well update the brake hoses - since they are from 02.
Do you all upgrade to SS braided lines or just go with OEM rubber again. The OEM have lasted this long so that is what I am leaning but thought I would ask.
Oh - this is an on road only vehicle - so no worries about snagging a line....
Thanks,
Joe
Thanks,
Joe
OEM. Honestly, I don't think you'll notice a difference between NEW OEMs and SS lines, provided you do a complete fluid flush. For more sportier applications with more severe braking conditions, it would be a good upgrade but for something like the Excursion, I feel it is a waste of money.
New rubber lines, fresh quality fluid, full proper bleed and you'll be good to go. A complete brake fluid flush on my Ex made a HUGE difference a few years ago. Now I do the fluid ever other year to keep it fresh. I think brake fluid is one of the most overlooked maintenance items, yet it is really easy to do.
GL.
GL.
I have read SO many post that say it's by far the best thing ever (SS) but I noticed no difference. I have full front and rear (including the 3rd line in the back) setup. There is one thing though... I'm like 99% sure my MC is junk. Once I get that swapped who knows how well the truck will brake.
And also agree that SS lines are great for sporty applications (sports cars and whatnot) but most street driven vehicles are fine with good condition rubber lines.
That is what I think is the key - I think any new brake line will be an improvement over original - since the newest is 12 years old right now.
OEM uses "HR" or regular expansion hose,
PTFE core braided line is "HL" or low expansion hose
This chart shows the difference in expansion for 3/16 brake hose at 1000 psi
Now figure out the length of the Excursion brake hose, x the 3/16 inner diameter to get the total volume.
Once you know the volume you can figure the difference.
Figure the volume of the 1.375 master cylinder bore.
Last but not least, iifc the Ex has a 6:1 brake lever
Solve for how much pedal stroke would be required to make up the difference in expansion.
( been a few years since I did the cals but it was less then the amount your shoe sole compresses when you walk and why race driver shoes are hard sole )
https://www.nhtsa.gov/DOT/NHTSA/Vehi.../TP-106-10.pdf
Sweet! Braided it is!! between them and fuzzy dice I should get easy 130hp at wheels AND a bump of at least 5mpg!
