Im finally starting to tear down my 400 and im looking for advice on parts and what all i should have done. right now i have a performer intake and holly 1850 and a new crane h-260-2 . the rods and crank look good but i need bearings and pistons, i have a set of heads that are polished and ported and milled .030 as far as i know. i picked up an engine that i can cannibalize and it is bored .060 over i think, at least thats what it says on the pistons. im not sure if its a 351m or 400. but some parts are interchangeable. any suggestions and ideas for the build?
You will soon find that there are basically two sources for pistons: Tim Meyer if you want good compression, and anyone else if you are satisfied with 8:1. I recommend Tim's pistons. In fact, I had him do the assembly work on the engine and then dyno it.
i am looking at the KB2347 the 13.3 cc pistons. and with the milled heads im wondering what the cr would be. what brand of bearings to use? which brands and special bearings that will work best for the engine. i just don't want all my work to go up in smoke!
Tim is the foremost 335 Series guy in the world. He builds them all the time, so tell him what you have and ask for his advice on pistons. You'll probably have to leave a message as he gets many, many calls for help and can't answer the phone for every call. But, leave him a message, tell him what you need, and he'll call you back. But buy as much as you can from him as we need him to stay in business. Where else can we get pistons? So I bought bearings, gaskets, cam, etc from him. And, by the way, you should do his mod to the oiling system: Oiling System Mod's - ???Gary's Garagemahal
maybe we can get him to chime in, i will be doing the building myself but i will have a shop clean up the block and heads, i can install and do everything else myself given the time.
i have a little update. its going to be a long project. but i was cleaning up the pistons and it has B 040 on the top of the piston. so i guess its been built up just a little. so what should i do when this has a pretty big lip and im not sure how much more i can take off safely.
