The "37's" thread, For us with 18's
My rake is still factory all I did was add tires it does Rub a little at FULL lock I emphasize the word FULL lock. Who drives the truck to FULL lock on a regular basis once you add any form of suspension lift even in the front to level it out you take any and all aerodynamics from the factory hence your miles per gallon go away down my Lie O meter is saying 19 average Mpg at 70 miles an hour on interstate and it doesn't change hardly at all in town because I don't treat it like a drag racer My hand calculations for MPG is right around 18.5. I love my truck I love my tires it's what it should look like from the factory
I would like to know your take measurement also and Your cab height at tallest point.
Think this all relative to thread....if not sorry OP.
on my old truck I ran the nitto trail grappler MT's in a 37x12.50/18 they are load E rated and can handle 80 psi so the stupid light on the dash doesn't go off.
on my current truck I am running a toyo Mt in a 38x13.50/18
but I also went from an F350 to a F250 and am not hauling as much any more.
My first set of nitto's I got 50,000 mile out of them.
its a tire I really like
How do you like the Toyo MTs vs. the Nitto MTs?
Why did you change to the Toyos if you like the Nittos?
What lift are you running to fit 38's?
Thanks!
#29
