Be aware, the aftermarket master cylinder may not be the same as original. I am running an aftermarket MC on my F4 and would like to run a remote fill also. I have thought about brazing or welding a fitting into the MC top. I, too, am open for ideas and discussion.
I have a MC in the shop, I can measure the thread tomorrow. What would be needed to hook up a remote reservoir? Would a cap with a hose fitting or a threaded hole for a fitting work?
Mark
Good question, as my new master cylinder is an aftermarket also. So I took the new (aluminum or pot metal) cap and tried it on the old unit, and the thread pitch and diameter (straight thread) are the same, so they are interchangeable. If I could locate a steel or cast iron cap I'd be in hog heaven.
I'm thinking as a last resort to use a pressure test plug, however I don't know about the compatibility with brake fluid, but knowing that steel and neoprene are ok, I'd probably go with it.
I think that cap has to be vented so you don't get a air lock. The treads are a normal
60 degree NF. I machined many of those from brass easy job but did drill a 60 thou
breather hole. You have a friend with a lathe then its a snap.......sam
This would be used with a remote reservoir which would be vented. I have access to a lathe but it's on a ship, so that's out.
The threads on the cap of the Wagner MC that I have measures 1.230 O.D. x 18 TPI. The cap fits very loosely so the thread may actually be 1 1/4 -18. The sealing flange on the cap is 1.5 O.D. The cap would be very simple to machine.
Mark
