Truck won't start sometimes
It will get worse, but you may or may not have to replace the pump. You need to get some gauges or scanner that can read live data to find out what your oil pressure (HPOP) is and then determine if you have HPOP system oil leaks or not. Is your truck an early or late '04? If the ICP sensor is on the passenger side valve cover it is a late '04 and 1 big possibility are the stand pipes and dummy plugs, the early '04 was a different setup and uses a different stand pipe, but they can still have several places for a HPOP leak. There is a lot of info on the net about testing for leaks and you really need to do that before just throwing parts at it. That being said you should have the 1st gen. high pressure pump and that is a weaker design than the '05 and newer, if you do need a pump I would consider ONLY the Adrenaline pump from DieselSite, expensive but Factory pumps are now all remans with a very poor track record. Another thing to examine closely if and when you get into the motor far enough to access the pump is the J tube from the pump to the branch tubes, they sometimes have a hole worn in them from lack of clearance to the HPOP cover. If your truck is over 100K on mileage I would recommend a new pump even if you find some leaks as that seems to be the threshold where the pumps start to fail.
