Intermittent Rough, need troubleshooting help
Hi everyone!
I'm in the middle of changing out my glow plugs and wire harnneses, I went to exposed some of the wire so I can splice the new harness in and I'm seeing this cable wrapped around these three wires. Is this necessary? What is this? I can only imagine that it is for "noise" reduction. Some info would be great, also what is this tin foil stuff?
thanks,
Rob
thanks,
Rob
can I run the engine with valve covers off? I don't want to put everything back together until I know it's running good.
Runs beautiful. Fired up quick.....I disconnected each injector and each one mis fired.
What can I do to make sure my glow plugs are turning off after engine is started so I don't have to do this again in a while?
another problem I have is excessive smoke, and it gets into the cab, give me headaches....when I started it and when it ran it was smoking pretty good.....not pushing out smoke like a train or chimney, enough I had to hold my breath to pull the injectors.....is this normal? What should I do?
what is this relay?
Picture of it running......cant really see the smoke in the photo.
Yea I need to get on this exhaust leak.....gotta help me with some links here not caught up on all this, what section of the exhaust are you talking about? What's international bellow up pipes? Thanks.
btw, as for my progress.... put the covers and intake back together, went to start it and, it turned over a litthe and prematurely let go (greasy fingers), trif starting it again and it's just "zinging" not engaging....so putting a new starter in tomorrow.....gets me thinking......hope I didn't do something wrong
rob
if I do, what should I do? Change it? Yikes....
btw, yes smoking a lot with covers off....but I am having a problem with fumes/exhaust getting into the cab...
knotty, thanks....Im about to go work on it next hour or so, I'm afraid I might see missing teeth on the fly wheel.
Cab fumes need to be deals with. Find the leak first
okay kool, how do I move the fly wheel? Crankshaft pulley?
#28
#30
Do I didn't solder them, I used high quality butt connectors thou.....didn't know I had to solder them. I could test it with a mega-ohmeter to get my true resistance if I need.
Teeth were fine, new starter installed and works. Still no idea where the exhaust is coming from....driving me nuts...with it idling I tried feeling around for any air....maybe it's the turbo...I'll look into that more.
As for an update here, I'll try not to sound confusing.....
Put the valve covers and intake back together and installed new starter.....
btw, Idk if I mentioned this has the TS Chip installed....
It was idling fine, starts up beautiful and quick! Then all of the sudden it starts running rough again, but this time very consistent...as I jump the RPM up to 1500 the roughness is going with it...so I shut it off...Disconnect the IDM connector and follow this:
Test 2&3 are good, test 1 was showing 0 ohms (continuity) between the injector power pins....for example pin 24-6,21,8,20 were 0, same with the other side of the bank....so I'm like
So I disconnect the connectors off the valve cover and double checked my wiring threw the IDM connector and it all checked out......it's not my wiring.
Next I reconnect the IDM connect back into the IDM & run the engine again.....ran it for like a minute or so....Pull the IDM connector back off and re-ohm'ed both banks and each injectors and guess what! Test 1 pass and everything was a consistent 2.9-3.1 ohms.....
So I know it's not my wiring...or the injectors......I'm starting to think it's the IDM now.... So I bought one online and it'll be here in a few days to try it out. If it doesn't fix it I'll just return it but simply box swapping it out for troubleshooting I think is worth the shot.
What do you think? What else to check? I'll post some photo's next thread they are on my phone.
Rob
Rob
