HPOP oil lines
Hey sous you wouldn't happen to know what I would need fitting wise would you? I'd like to have everything made up and ready to go when I rebuild the hpop, I've been digging and haven't really found any specs on updated oil lines
x2.
I've never had a problem with the lines. It's been the fittings that have given me issues over time. The "new design" definitely look better compared to the older ones when I put them on last year. I was replacing a bunch of HPO stuff so replaced the lines as a preventive measure since I was already deep into my valley (and wallet).
Just buy them from Ford. New ones are about $100 each. You can get them online from someplace like Tousley Ford ( now known as Auto Nation White Bear Lake), or if you're lucky, you can get your local dealer to match those prices. I have 2 dealers near me ( actually many more, but 2 that are real close). One will not match online prices. One usually will with some mild arguing. By the way, those online prices are usually cost + 10%, which seems to be the most common "shop" price/'discount that they will give to commercial customers.
As far as the hoses themselves, they are actually made by Aeroquip. I don't think you are going to beat their quality. I am pretty sure the quick connect fittings are also a proprietary Aeroquip design.
When I had mine replaced, I just got 'em from Clay.
HPOP Line - Driver Side Head
HPOP Line - Passenger Side Head 99.5-03 - Riffraff Diesel Performance
I know, that doesn't help with your question. Sorry, I don't know what fittings, I just figure if you change your mind, you'll have options.
Stewart
Stewart
CNC Fabrication LLC, Diesel Performance, CNC FABRICATION 7.3L SD REPLACEMENT HPOP LINES CNC-SD-HPOPKT
here you go. same hose less the leaky special fitting ford uses and less money. win win..
mprima
01-22-2018 08:16 PM
jstihl
12-17-2017 11:10 AM
