VIN PLATE DECODE? 1965 F250 CAMPER SPECIAL
Old 04-18-2017, 12:40 AM
indigoblue's Avatar
indigoblue
indigoblue is offline
Howdy all, Newbie here.
The plate on my door panel has the following info, can anyone help me decode it?
(see photo)
Also, its missing left drivers door window, any tips as to where to get a replacement from?
This truck has been under a tree in a forest in Oregon for about 10 years, has had the dash removed (will need replacing, all wiring under dash will need to be rewired), and will be in need of a lot of TLC to get it rolling... and I'm no mechanic.
Expect a ton of questions about it, or please help and point me to some good threads about it.
Thanks.
Old 04-18-2017, 07:49 AM
66v8baby's Avatar
66v8baby
66v8baby is offline
The VIN indicates it is a '66 model;
F25 = 2 WD F250
Y = 352 V8 (In '65 it was a D)
K = Kansas City assembly plant
804943 is the consecutive unit number.
129 is the wheel base (long bed)
FM is two tone Light Blue and Wimbledon White
B81 = Custom Cab Medium Blue Crush vinyl and Cody weave pattern bench seat
G = MX Cruise-O-Matic
7500 = GVWR
172 certified HP @ 4000 RPM
Edit: I'm pretty new at deciphering, so if I got something wrong, I'm sure someone will jump in to correct it.
Old 04-18-2017, 09:42 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
F25 = F250 2WD
Y = 352 2V (In '65 it was a D).
K = Kansas City MO assembly plant.
804943 = 1966, the consecutive unit number.
129" Wheelbase.
FM: F = Light Blue / M = Wimbledon White.
F250 = F250 2WD .. 7,500 lbs. GVWR
B81: B = Medium Blue Crush Vinyl & Medium Blue Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
G = MX Cruise-O-Matic.
24 = Dana 60 Rear Axle / 4.10-1 / 5,200 lbs. Rear Axle Capacity.
7500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4000 RPM
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
The right & left door glass is the same and it's the same for all 1961/66 F100/1100's.
The door glass is flat, so any autoglass shop can cut a new glass from glass stock
Old 04-19-2017, 11:55 PM
indigoblue's Avatar
indigoblue
Thanks for great responses!
Good to note about windows, makes it easier.
Old 04-19-2017, 11:58 PM
indigoblue's Avatar
indigoblue
Drivers window missing
i imagine same flat glass for both driver/passenger windows on f250 as for F100's?
Old 04-20-2017, 09:37 AM
6t6merc's Avatar
6t6merc
6t6merc is offline
I suggest you look for used wiring from a truck in that same wet climate. There is usually nothing wrong with old wires and people selling parts don't want much for them. And it just plugs in.
jpk_ks
01-24-2018 12:47 AM
Nose is
06-05-2015 03:56 PM
DangerBoyForty
09-14-2013 02:11 PM
oldford65
11-28-2011 03:27 AM
kdda191
05-25-2011 10:14 PM
Quick Reply: VIN PLATE DECODE? 1965 F250 CAMPER SPECIAL
