So I took this valve off and it appears that the seals are ok. I did order the seals from riffraff diesel so I'm going to put those in place I think. Where does this black vitron o ring go for the valve stem?
What is that fitting there? The big one under the steel line. It's leaking to my driver's wheel well. Some sort of brake line by the looks. Thought it was my power steering cap or oil cooler at first but I caught it Sunday and the brake fluid is down.
So I took this valve off and it appears that the seals are ok....
The seal that gives isn't facing the camera in that shot. Interesting colored fluid on the O-rings... methinks you may be due for injector O-rings. Was the fuel filter black per chance?
Can't remember it was a while ago. It was a wix filter but I switched back to motorcraft. I think it was dark gray. I don't know what color the element was to start with because I didn't own the truck. It doesn't smoke or burn oil. I did have fuel and dry oil from the valley on my fingers when took it off so it possibly got on the seals.
