Disc Brakes - what are running?
Old 04-16-2017, 09:04 PM
Nwflyonly
Nwflyonly is offline
Nwflyonly is starting off with a positive reputation.
I have a 65 f100 that I want to put disc brakes on and wondered who's done the conversion and what did you end up installing?
Old 04-16-2017, 09:24 PM
anthony myrick's Avatar
anthony myrick
anthony myrick is offline
anthony myrick is starting off with a positive reputation.
73 up f100
get the Ibeams with brakes and the proportioning valve
Old 04-16-2017, 09:54 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
ultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud of
'73-'79 F100 or '75-'79 F150 front disc suspensions are all compatible on '65-'72 F100s.
Entire disc brake front suspension from a '77 F100 I installed on my '69 F100.
You'll also need the frame brackets on each side where the hard line meets the flexible brake hose going to the front caliper.
If you wanted to run a '75-'79 F100 - F350 1-1/8" front swaybar, you would need to get the front suspension from a '75-'79 F100/F150. The radius arms will be factory notched at the forward end of the radius arms to receive the locating pin on the swaybar endlink brackets. '73/'74 radius arms will not have the notches in them.
1978 F250 Camper Special front swaybar on my '69 F100.
To get the maximum potential out of the front discs, a brake booster would be a good idea. '75 F350 dual diaphragm booster/firewall brackets with a new '95 Ford Explorer 1-1/8" bore MC. My disc/drum brake valve is an NOS item that's for an '84-'86 F150/Bronco.
Old 04-17-2017, 05:43 AM
jowilker's Avatar
jowilker
jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Had 66 F100 352 3 spd, dropped the complete front axle, steering gear set, bought a 76 F100 360 C6, pulled it along side of the 66 dropped the set, slid it over and bolted it up in the 66, best way to go, as you have all the parts for the upgrade right there.
John
Old 04-17-2017, 09:12 AM
Amish65F100's Avatar
Amish65F100
Amish65F100 is offline
Amish65F100 is starting off with a positive reputation.
My truck has the front end of a 73 F100 swapped in along with the 73 disc brakes.
TEMiller
1968-2013 Full Size Vans
17
05-06-2019 08:19 AM
denny7170
10-19-2016 01:05 PM
mspin54
10-01-2016 12:13 PM
Catanna69
15
08-29-2016 08:52 PM
mecone
1966 - 1977 Early Broncos
04-13-2016 03:34 PM
Quick Reply: Disc Brakes - what are running?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
