Cab and Chassis gas tank question
I have a '77 F350 flat bed dump. It recently developed a leak in the In Cab tank.
I don't really want to put another tank in behind the seat.
My problem is that the normal areas between the frame rails/under the bed are pretty much taken.
The dump is a PTO. This takes up the space directly behind the cab.
The hydraulic ram is large, and takes up the space in front of the axle.
The pivot infringes on the area behind the axle.
This leaves me few options.
I'd like to mount a tank outside the frame, in front of the rear wheels. Kind of like an under mount tool box.
Is this a legitimate location for a tank? I see a lot of Isuzu type trucks with tanks outside the frame, but is that because they are diesel, and not gas?
Any thoughts would be greatly appreciated.
Scott
Scott
I'm pretty sure I've seen old 2 ton and 5 ton trucks with gas engines and fuel tanks mounted the way they would be on a more modern diesel. I can't swear to it, and everything I can actually put my hands on with a tank like that has a diesel. It definitely seems safer for a diesel tank. I've had more than one four-wheeler bounce off the side-mounted tanks on my big truck over the years, and I lost a strap once, and easily could have dragged a hole in the tank. With diesel, that wouldn't have been much more than a $500,000 EPA clean-up bill for sterilizing about a cubic mile of contaminated dirt. With gas, the sparks on the road would have been a big kaboom.
Anyway, I did some digging for you, and came up with a metal fabricator that sells such tanks, clearly labeled for gasoline, and clearly meant to mount outside the frame rails. Caveat emptor, YMMV, all hail the '77 F350
Truck Fuel Tanks - Cylindrical Safety Fuel Tanks Top Fill
Let me know how it goes. I'm not thrilled with the tank in my new truck either. "Gee, is it ok to weld in here with this gas tank? It's not emitting vapors or anything, surely?"
I think some one got sued (Chevy) for designing a gas tank outside the frame? I think it exploded on a side impact accident.
Whats wrong with a gas tank behind the cab, Ford designed it to be safe enough to sale them that way.
Maybe see if a 80/90's Bronco II tanks would fit back there somewhere.
zsir
13
11-09-2003 09:12 AM
