What do you guys do? paint or no paint
As I reassemble my truck I am either replacing with new or cleaning the old bolts and nuts that hold various parts on. Can't tell if they were factory painted or not. To many years of rust and wear. Do you guys touch up the bolt heads with paint or leave them natural?
I replaced the bolts holding sheetmetal together with gr 5 and left them natural. My Ford truck are not built to show, only to drive and enjoy. My T birds were done to factory specs.
If you are doing a show vehicle, the rules vary. For the parking lot crowd, you may want to do chrome.
For a true restoration, the rules change again. You'll want to check against the rules the vehicle will be judged against. Ford was not concern about bolts and nuts lasting a long time, just hold the tin together and get it on the street.
I replaced some with SS also - - - but make sure that you use anti-seize compound or they will gall and you will have to cut them off. Some will gall without antiseize before they ever provide clamp load on the part.
Other places I just used plated grade 5 bolts. I painted them where appropriate like on the frame.
I like Seymour Stainless Steel paint on stock steel bolts. Wire brush the bolts and shoot a little paint on them. It's not overly bright and has a satin finish. They look natural but avoids rust. Used clear on the fender bolts for a 1966 Mustang engine compartment detailing a while ago and it has started to yellow a little.
If you really want to get fancy, I've know guys who have used Eastwood's Electroplating System. Or for black oxide, Caswell Plating has kits for steel and stainless - only takes a couple minutes at room temperature, odorless, and no electrical power is required. (I've never tried it.)
Thanks to all have offered suggestions and shared their experiences. I am always impressed with the talent and knowledge of the guys on FTE.
I've never used this but I wonder how this would work? Copper looking bolts for you dark siders?
https://steelfxpatinas.com/shop/stee...nas/copper-fx/
Fasteners is a good topic. When will these companies that offer OE fastener kits for the late 60's early 70's cars offer them for these early Ford trucks? Doesn't have to be exact, just similar and plated (not chrome). I've been forced to use grade 5 zinc plated fasteners from hardware stores or McMaster Car for the sheet metal. Works fine but doesn't come close to mimicking original.
chad.deraps
12-04-2012 05:42 PM
montego69
03-15-2012 03:45 PM
