Truck Has Horrible Cold Start/Run Problem! At my wit's end.
Old 04-26-2017, 09:59 AM
AKHunter93's Avatar
AKHunter93
AKHunter93 is offline
Well, back to the drawing board I guess. Unplugging the sensor made no change, as you suggested.
I suppose now I ought to look at wiring the valve open. I see quite a few people talking about doing this, but I've not been able to find instructions online. Is there a set of instructions anywhere that you know of?
  #32
Old 04-26-2017, 12:04 PM
knottyrope's Avatar
knottyrope
knottyrope is online now
its not electrical wiring
Using steel wire, metal coat hanger to keep it open
IIRC the tang should be against the stop
or take off the down pipe and drill/grind the rivets of the valve off
  #33
Old 04-26-2017, 04:38 PM
AKHunter93's Avatar
AKHunter93
I understand it's not electrical wiring.
This can be done without removing the turbo, right?
  #34
Old 04-26-2017, 09:11 PM
knottyrope's Avatar
knottyrope
Yes. Just wire it around the post on the valve shaft and wrap it to something solid. I'm doing it on mine just to be on the safe side. I don't use it often in winter and can wait for heat still.
  #35
Old 04-27-2017, 11:29 AM
AKHunter93's Avatar
AKHunter93
Thanks. I'll look in to getting it done this weekend and report back.
  #36
Old 04-27-2017, 08:02 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
Here's a quick video to me they sound alike
  #37
Old 04-27-2017, 09:05 PM
AKHunter93's Avatar
AKHunter93
Not quite the same. Different idle sound (to my ear) my oil and coolant are clear, oil cap doesn't blow off, no CEL, etc. Different issues, I'm confident. Mine idles smooth, and it's dropping RPM because the engine is automatically defueling due to high EBP values. I'm pretty sure that's where my issues are stemming from.
  #38
Old 04-28-2017, 12:53 AM
nateairman's Avatar
nateairman
nateairman is offline
The valve comes off with three 12point 5/16 bolts. The down pipe should lean over enough when you remove the clamp. The actuactor is attached with a spring socket to a ball on the arm that is attached to the valve.
Remove the valve drill the two wee rivits holding the plate to the shafts remove the plate and stick back together.
Another thing in your photo the engine bay is very dirty. Have you pressure tested the charge side of the system for boost leaks? Primarily thinking your plenums are leaking. And the orange boot going to the turbo is known to crack and let unfiltered air into the engine.
I found a small boost leak in my intake and thought, that isn't too bad it can't make that much difference. Boy was I wrong. Cleaned up the area real sealed the plug and WOW! I have to re train my self on the skinny pedal.
  #39
Old 04-28-2017, 04:55 PM
AKHunter93's Avatar
AKHunter93
No, I have not checked anywhere for boost leaks, but it is something I've been meaning to do. Highest boost I've seen is about 13 psi, which seems low to me, even for a stock truck.
  #40
Old 04-28-2017, 08:57 PM
knottyrope's Avatar
knottyrope
My stock truck sees 20 at around 3000 rpm in third
  #41
Old 04-28-2017, 10:14 PM
AKHunter93's Avatar
AKHunter93
Exactly why I need to check mine for boost leaks
  #42
Old 05-28-2017, 03:00 AM
AKHunter93's Avatar
AKHunter93
Well I'm happy to report that I think I've come to a solution on this cold run deal. I could watch the butterfly valve closing under throttle when it's cold, and after wiring it open today, it drove perfectly normal from a cold start. We'll see if it continues, but I suspect that it will.
As for the boost leaks, I got the tool built this week and just need to test it. Hopefully tomorrow; serviced four wheelers all day today.
Thanks for your help, all.
  #43
Old 05-28-2017, 09:16 AM
knottyrope's Avatar
knottyrope
I wired mine shut and big difference.
They should not do this but it's been reported in quite a few threads and now we have more confirmations.
Next thing to try might be armature clearance. I have a set of shims waiting for some free time to install on mine.
  #44
Old 05-28-2017, 12:19 PM
AKHunter93's Avatar
AKHunter93
Yeah, I really don't understand how it can be moving at all with the actuator plug disconnected, but weirder things have happened.
Now to chase a pesky fuel leak and boost leaks...
  #45
Old 05-28-2017, 09:35 PM
knottyrope's Avatar
knottyrope
Fuel pump, bowl seal kit and new fuel hoses fix most of them if the hard lines are not leaking.
Hopefully the boost leaks is an easy fix. I replaced all three of my boots and the turbo o ring.
Might test my plenums under pressure once my compressor is wired up.
Quick Reply: Truck Has Horrible Cold Start/Run Problem! At my wit's end.
