5.0L/302 Lift Points
This is a 5.8 & note the washers taped up to retain even spacing.
I used identical length chain spacing on the rear for balance.
Of course this was a new build & I cared about a lot of things you probably don't, so there is that.
I also used a load leveler. I recommend pulling the crank pulley.
It makes up a lot of front to back distance when angling up/down.
Hope this helps.
How it came out once before:
Hope this helps.
BigBlueBomb
26
01-16-2016 07:58 PM
