The front AC works fine but the rear quit working a couple of weeks ago. I started working again a few days ago but now its dead again. I found instructions for the EATC self test and i get code 1251. What do I need to do now ?
Here's what I came up with, B1251 A/C in-car temperature sensor open circuit.
I guess the first place to check is at the sensor itself, if its got a break in it you'll get that code. I suppose a bad sensor would keep the A/C from running since the EATC wouldn't know what the air temperature is.
