1st Oil change with Filtermags on
#62
I could just cut it open and post the pics but I don't want to be accused of doctoring anything so I want to video the opening so everyone can see what I see when it's opened up and cleaned. I have never posted video before so be patient...I will get it done. There's a lot of stuff going on now and I am a master procrastinator...I have a YouTube account and maybe I'll post it there...
#63
Thanks for sharing what you are doing Overkill - Internet is a rough place. You can't say you had a good experience with something and not have people attack it.
I do remember when even the OEMs put magnets on the end of oil drain pan plugs and when the oil was changed they always seemed to have gunk on them.
If this makes anyone feel better, like adding extra fuel filters, then great. Go for it. This isn't a huge expense and could get moved to another vehicle easily, so this isn't as much as investment as other products.
Stay safe out there.
#64
#65
on
@ Overkill2,
Thank you for taking the time and effort to do your 1st post.
I just came across it by chance while doing some google homework.
I've used a powerful speaker magnet on the oil sump for several years, and I know of some local drag racers that use a handful of small magnets on their oil filters.
I did not know about the filtermags until now. That's actually what I want, and what I've just ordered.
I've also recently come across the following :
EZ-115 : NPT 1/4-18 | EZ Oil Drain Valve
These are brilliant to replace the block and radiator drain plugs, as well as tranny and oil sump plugs.
I fitted them and tested them. No leaks, and no annoying mess when draining.
The picture below shows their size with the marlboro box to help with perspective.
Laterz.
Laterz.
#66
@ Overkill2,
EZ-115 : NPT 1/4-18 EZ Oil Drain Valve
Laterz.
Laterz.
Yes, I have seen the oil pan drain valves before and most of the guys here use these:
For Ford 2016 F-350 Super Duty 6.7L V8 Turbo Diesel
#67
ditto
either wrong oil wieght for weather conditions, too much time on the oil (maybe use severe duty schedule instead) or the oil does not have enough zinc, phousperous, boron
its cool that the magnets catch it, but whats cuasing it
#68
Hey *****, sorry for late reply...WAY LATE. If you didn't go to 1st page of thread, there are pictures which show the outline of each magnet.
#69
I'm at about 21,500 miles currently and the truck runs like a raped ape. If I have any catastrophic failure** of my engine, I'll let you guys know.
**Man, I hope I didn't jinx myself as I just read Lar man's thread about his 16 6.7 Powerstroke.
