My First Truck!
#91
#93
I'm not sure, honestly. I need can't find any info on them, because I don't know what to search for, and I'm too lazy with all the other work to pull a wheel and take a close look.
When it comes to spacers, I've NEVER been comfortable with them. Some people use them and love them and never had a complaint. I guess for a road car I'd feel a little easier, especially if it was something that bolted to the hub itself for additional security.
However, on a working truck like that that sees all sorts of terrain and loads, I will NOT use spacers.
#94
So, I've got a question concerning the turn signal stalk; is it always really easy for it to click off at the slightest movement of the steering wheel?
It's to the point where it will return to the shut off position when I START making my turn. The sensitivity to motion is so high that even just keeping the wheel straight going down a turn lane before making a turn will often times shut off the damn thing.
Occasionally it won't lock into place, usually when turning right. Is there some kind of clock spring mechanism that's worn out?
#95
#97
Well, I was going to go for the cheapest, but I came to the realization that in most cases, OEM is the only way to go. I only ever get OEM for any of my Mercedes when I can, and often just look for the best deal on the web. Pay now and cry once, as they say!
Ordered a Motorcraft replacement turn signal stalk, and it just arrived!
Will be getting it installed in a bit.
#98
Took the chance at rewrapping my steering wheel instead of taking a chance on finding one in a yard in good shape or spending a hefty sum on eBay for one not much better than the shape mine was in.
I've never worked with leather like this before, and stitching was never my strong suit, but after this I really like leatherworking and my stitching skills definitely saw some improvement.
Is it perfect? Not even close. My stitches are still off in many areas, and the pieces weren't cut exactly perfect, but it was my first time and I was kinda in a hurry to get it done so I can drive my truck again. If I had to do it again, I'd go with a thicker, stronger leather.
Anyway, here's before:
And here's after:
I went with royal blue thread for the stitching to match the exterior of my truck. I like it!
And here's after:
#100
So last night I swapped in some LEDs for the brake lights, and they looked great and worked great.
However, on my drive this morning, I noticed I had no cruise, and that at 60+ mph, the transmission would shift back and forth between 3rd and 4th. If I was on the accelerator at that speed it would shift up to 4; conversely letting off the accelerator to maintain my velocity would cause the transmission to shift back into 3rd!
So, I was smart and carried my original incandescent bulbs and simply swapped them out. Cruise control was back and no more wonky shifting.
It would seem that while these LEDs worked, they draw so little current that the truck thinks they're out, so that disables the cruise control, which in turn somehow also affects the TPS (this is my best guess) somehow.
Should have opted for the CAN-BUS compatible bulbs; certainly this could be fixed with a resistor, but I'm not going to go through all that right now.
#101
#102
Where did you get your bulbs? I got mine from super bright, like usual.
#103
I posted from my phone, that's why my sig didn't show up....lol. Yes it's an automatic with the E4OD, and I got my bulbs from Super Bright also.
It actually is a pretty common problem with LED's in these trucks, normally the flashers will blink really fast as if the bulb is blown and the torque converter will get all screwy.
I was told I would need resistors, but I just picked up some electronic flashers from autozone and that did the trick. Autozone Don't forget to get one for the hazards aswell
Did you only do the brake lights so far?
#104
[QUOTE=Azryael;17162030].
I put a leather cover on my old Z3 and made some mistakes in the stitching. I called the vendor and they gladly sent me another spool of stitching. When I redid it, it took about 1/3 the time and it was much better. I tightened up the stitching a lot. I also did it on the car and the stability helped.
#105
[QUOTE=sandymane;17168163]
