Do I need bigger injectors? Gt40p, and cam swap
The computer will automatically adjust the fuel to accommodate air mods, to the extent of which it is capable to do so. The stock system will support 250-275hp with no outside changes. If it is lean, and you have strong fuel pumps (no drop in fuel pressure that would cause lean), the next step is a bump in fuel pressure via an adjustable fuel pressure regulator or larger injectors combined with tuning software to calibrate to the new injectors. The former is much cheaper than the latter.
Indeed you are correct, I've been running 460 comp and inj in my 89 for quite a long time now.
on
And did you calibrate the wideband system during the install?
That is the most important question of course so this reply is directed at the OP.. an A/F ratio should always be accompanied by the conditions under which it is achieved, otherwise it is useless information. 15:1 AFR while cruising under light throttle is exactly what these trucks were designed to do, but if that is with the throttle wide open and accelerating that is not at all acceptable and suggests a weak fuel pump.
The computer can normally easily adjust cruise and light throttle conditions to the target afr regardless of how far from stock the engine is, as a small change in duty cycle goes a long way under light load conditions.....it's the heavy pedal high load wot where the stock injectors, even at high duty cycle, cannot keep up. Watch the afr at wot for a long 3rd pull and see if it starts to creep up to lean as rpm increases. If so, tuning of some form is required. If it stays in the 13s to red line, you have nothing to worry about.
I like going back and reading my old threads. The trucks running great still minus a over heating problem but I think I have that under control. The wide band usually doesn’t go any higher then 15.5 on the highway but goes down to 12-13 when it’s floored. Just put some 4.10s in it. That woke her up some more
BlueOvalBoy19
23
04-20-2010 08:59 PM
choochoof150
11-26-2007 09:55 PM
