Dtc
Old Apr 10, 2017 | 10:23 PM
Duck410's Avatar
Duck410
Dtc
I've gotten a P0275 and P2290 what would those be
Old Apr 10, 2017 | 10:45 PM
Yama4fitty's Avatar
Yama4fitty
P0275 - Cylinder 5 Contribution Balance
P2290 - Injection Control Pressure too low
Old Apr 10, 2017 | 11:01 PM
Duck410's Avatar
Duck410
What would be the fixes for them
Old Apr 11, 2017 | 07:01 AM
bismic's Avatar
bismic
What are you driving, what mods do you have, done any recent work?
What scan tool did you use to pull codes, does it read live engine data?
Batteries fully charged, oil levels good, filters been changed recently?
You have to help us out - troubleshooting over the internet is a challenge even WITH this type of information. Without it, I suppose we could guess at an answer, but that can get costly.
Old Apr 11, 2017 | 09:26 PM
Duck410's Avatar
Duck410
03 f250 fx4 everything checks good on levels and I'm runnin the economy tune with the edge tuner that came with the truck one thing I've noticed the last week or so is that it kinda stumbles till it gets to operating temp
Old Apr 11, 2017 | 10:12 PM
bismic's Avatar
bismic
P2290 (running code) on a 2003-2004.25 6.0L is most likely caused by, in order of likelihood:
1- Failing, cracked and leaking ICP sensor and oil damaged wiring at the sensor
2- A weak or failing High Pressure Oil Pump
3- IPR valve
This is a "running" operation code.
The codes can be from an actual mechanical failure (see list above) or even faulty programming.
Please pull and inspect the ICP sensor and the connector (pig tail).
Also, it would be helpful to see live engine data:
ICP pressure
ICP volts
IPR % duty cycle
When cranking, at low idle, and high idle
First on a cold engine, and then on a hot engine
norman2012
Oct 23, 2018 01:15 PM
jdneal88
16
Jan 2, 2017 12:35 AM
1979BEAST
22
Jan 1, 2011 10:19 AM
Bergerson
Dec 12, 2009 01:22 PM
Frank Stahl
Feb 23, 2007 07:31 PM
