2005 F150 kicked back multiple codes and is running like crap
Ok, I hope that someone can help me with these issues. Sorry if this is a little long but let me give you all the info. I own a 2005 F150 King Ranch Supercrew 5.4l 3v with 190,000 miles. The truck is straight and in beautiful condition looks wise and has a new transmission in it. But mechanically I have some issues. I just replaced all the plugs and coils with motorcraft parts. I also replaced the VCT solenoids, also with motorcraft. All in the last 6 months, it was running great until last week. It started to shutter and shake and at every light I had to put it in neutral and rev it to keep it from staling out. I limped it home then the next day when i hooked up the code reader i got 8 different codes. Here they are - p0010, p0020, p0022, p0171, p0175, p0300, p0305, and p0308. I know the last 3 are just random misfire codes and probably a result of whatever is wrong. Also my engine did have that annoying diesel tick, but from what ive read that's only annoying and shouldn't cause problems. I've been told by family and friends that are mechanics that the timing chain jumped a tooth but it'll still start up and run just not well. So I thought that if it jumped a tooth it wouldn't start at all.
I'm hoping that it's only a cam positioning sensor or something easy like that rather then having to open up the from on the engine and replacing the timing chains, tensioners, and all. Any info would be helpful.
Thanks
Thanks
Could you watch the fuel pressure after shut down to see how fast it bleeds off?
Our '03 will hold fuel rail pressure of 20psi after 2 days.
I know my father in law has a gauge that I could hook right to the back of the rail. I'll try that and see how much and how long it holds
If not, the should be a pressure sensor for the computer to get the data which would be in the OBDII data.
jjward101
2004 - 2008 F150
15
07-16-2014 12:13 AM
