Can't get exhaust manifold bolts off. Can you help? - Ford Truck Enthusiasts Forums
Old 04-10-2017, 04:28 PM
iron1951 iron1951 is offline
iron1951 is starting off with a positive reputation.
I can't get my exhaust manifold bolts off. They are in bad shape. The 10mm is too loose and 3/8 just rounds. I have had the torches on them too! Can the bolts be cut off with a torch?? Haven't broken any. Can't get the bolt heads to move. It's an 04, original manifolds. I am working the driver's side. I can't figure this one out. Help to get this manifold off would be appreciated.
Old 04-10-2017, 04:37 PM
Copper.Farm's Avatar
Copper.Farm Copper.Farm is online now
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
Search on YouTube, many ideas on varied extraction techniques.
Old 04-10-2017, 09:52 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
They are 8mm IIRC
Old 04-10-2017, 10:41 PM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Also use a 6 point and some Kroil.
Heat, soak then let it sit.
Old 04-11-2017, 01:33 PM
Thanks for the help. The exhaust manifold is off. I soaked the bolts last night and used "a lot" of heat this morning and they all came out, no problem.
But I still have another problem. Check my new post, Exhaust manifold is out BUT I can't get the bolts out.
Thanks
Stuck in the middle with you... applebaggins 1973 - 1979 F-100 & Larger F-Series Trucks 34 11-10-2017 07:39 AM
Exhaust manifold... jkais3r 1999 to 2016 Super Duty 21 10-01-2017 08:53 AM
Oh, for the love of the 7.3 SchaefferUSMC 1994.5 - 1997 7.3L Power Stroke Diesel 4 09-11-2017 10:30 AM
Upper exhaust pipe bolts from manifold? jpilk99 1999 to 2016 Super Duty 0 05-02-2017 05:07 PM
How do you get bolt off of 5.0 Explorer Exhaust??? 5.0 Heaven Explorer, Sport Trac, Mountaineer & Aviator 0 09-05-2016 09:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
