Test IAC
#31
#32
#33
After watching the YouTube video, this link tells how it worked for me: https://www.ford-trucks.com/forums/1...expensive.html
#34
Thank you. I have the O2 sensor out and once thats replaced if needed i will do the smoke test. The O2 sensor part # prefix E3EF threw me since that would be for an 83 model and in looking around on here that would be for (Cab over Engine) (1970-73), Pinto (1976-80), Escort (1981-later)
F = Foreign sales / Trans Am Racing...............very confusing since i have a 1985 f150 5.0.....morph.....has the paper cartridge fuel filter/no inline and no schraeder valve on fuel rail.
#35
Replaced the O2 sensor and no more code 13 but truck still has idle surge and runs crappy. Rescanned and came up with even more codes some of which i assume are because at throttle depression during test the engine hesitates and cuts out. 44 (thermactor air system failure) 34 (pressure feedback sensor voltage is high) 72 (insufficient map/maf baro change during goose test) 73(insufficient throttle position sensorchange during goose test) Why did all these new codes all of a sudden show up? I have not done the vacuum leak check yet.
#36
Ok I am no expert but it looks like the MAP/MAF and maybe the TPS is bad.
Then again it is telling you there was not enough change and could be "because at throttle depression during test the engine hesitates and cuts out."
What is the code 34 (pressure feedback sensor voltage is high) What PSI is it measuring? Could it be fuel PSI and have you put a gauge on it to see what you have?
I would try and clear all the new codes and re-run the test again to see if you get the same codes.
Dave ----
Dave ----
#37
44 is the air pump system, I would ignore that for now. 34 is your EGR sensor. I would temporarily take the EGR valve off, make a block off gasket out of a pop can or some other thin metal, and put the egr back on with the homemade block off. Then try it. If it straightens out, then you have EGR problems.
You are probably correct on the other codes, when the test told you to goose the throttle if that didn't happen you will get some other error codes.
#38
Trying to learn this stuff so if I ever get a EFI truck I will have half a clue.
So that code 34 is it because the voltage to open/close the valve is to high or the PSI in the EGR track to high?
I did not think they checked the track PSI but I don't know this system too well.
Other question does the valve work by vacuum or electric? If vacuum where does the ECM get its signal from?
Dave ----
Dave ----
#39
Dave ----
Dave ----
The other system they had is the pressure transducer type. This is the type they use on my little ranger with the 2.9 v6. This type also has a electric vacuum valve. It also has a conventional type EGR valve with a diaphragm. What it has additionally for feedback to the computer is a pressure sensor located off the egr supply line to the exhaust manifold. The supply line to the EGR is usually a large steel pipe, and off of this that have a small fitting with a line going to a little pressure sensor box.
Normally the exhaust system has backpressure as it's running down the road. The back pressure builds in the EGR supply pipe. The pressure sensor is reading this back pressure. When the computer decides it's time to add some EGR, it sends a signal to the vacuum valve which supplies vacuum to the EGR. The EGR opens. When it does, the pressure in the exhaust supply line will drop. The sensor sends this signal back to the computer. The more the valve opens, the more the pressure will drop. Like the other system, it constantly goes back and forth to modulate the EGR flow rate.
They use the same code for both systems.
#40
#41
Here is a link with the codes. If you go down the list they show 3 different egr systems, I am only familiar with the two I mentioned. And it shows all the different scenarios and the different codes that can be set.
EEC IV 2 digit codes
The pressure sensor type system gives a lot of trouble. Of course it's sampling exhaust gas, so that is hard on the sensor and it has a high failure rate.
#44
#45
I have replaced the tabp, the oxygen sensor and found a broken pcv valve. Truck now idles great but hesitates and seems underpowered under load. I now only get 2 codes, the 44 for thermactor system failure and 34 pressure feedback egr sensor voltage is high. My next course will be as Franklin suggested and block off the EGR and see what happens.
