1952 F1 build - "Dallas"
#151
#152
LOL...I think it’s a tight one. PV is from Charlie and I leak tested it on the bench. The jet plugs have Teflon coated gaskets from Charlie Price. The horn and body are NOS and the kit came from Daytona. It’s dry as a bone.
JB
JB
#153
Well we worked pretty much all day on fitting the front sheet metal and prepping everything for a coat of epoxy and high build. Still have to patch two places on the passenger door but we hung it to test the fit and it fit like a glove. The rain delayed the primer coats until the morning.
#155
#156
#157
#158
Oh I thought you were talking about the leaf springs LOL.
Yes the upholstorer added foam, lots of it. The springs were in really good shape and I think he only had to repair a few. It sits really nice and has good comfortable support. He is wrapping the sunviser and the armrests in the same fabric.
JB
JB
#161
#162
#163
Good question Ross, I forgot to give those details.....its nickel plated in an electroless bath from Caswell. It seems to work well although somewhat of a science project to calculate the bath replenishments. The items that are not pitted really turn out nice. I could level out the pits a little by plating in copper first but its mostly hidden hardware and I am just protecting the parts more than I am concerned about appearance.
JB
JB
#164
#165
Well it seems like Dad and I have stalled out the last few weekends. Bleeding the brakes has turned into a job lasting longer than it should, chasing leaks, etc. It seems like everything that can leak is so leak control has derailed our body work. Latest problem is the fan hub, it’s leaking. I have a new bearing on the way so hopefully that solves that. In beteeen leaks I was able to make new 2/0 battery cables. Hopefully next weekend we are back to sanding and priming parts.
