Anyone use FORSCAN on their Expedition?
What adapters are you guys using to connect to the vehicle with? Maybe that's the wrong term, but from what I see, FORSCAN runs on your phone and there's an adapter that plugs into the OBD2 connection and then into the phone. There's seems to be a bunch of issues with some of those adapters. What's a good one? Wireless? I get lost when I start looking at that stuff for some reason.
I would like to modify the following things.
If I buy an OBD module and get the Forscan software I can do all of these with my 2016 Expedition with Sync 3 v.3.0?
Climate control on right MFD
Tire Pressure on the left MFD (Like found on newer Fusion)
Outside temperature on right MFD
Heated & Cooled Seat Icons on home & climate screen sync 3
Windows close/open with Fob
Autofold mirrors (when locking/unlocking doors)
Also one other thing I've noticed when I first bought the vehicle is that when you're using CarPlay and you want to change the climate control you can't see what temperature you're choosing. I can't stand this because I want to be able to lower and raise the temp on both passenger and driver but we always have to exit CarPlay to make sure we choose a comfortable temp and not just guessing by turning the dial. I've seen on my new 2018 Fusion that it shows the temp in a spinning wheel when you change it (just like the picture below). Is there a way to implement this using Forscan?
nruggiero
27
08-18-2010 03:12 PM
