Blown Head Gasket, Still runs.
#31
Sounds like there is no thermostat in there right now to help the engine warm up.
BTW, Ford used 13# caps. Not sure about the aftermarket world.
#32
2X. I bet there is all kinds of rust and gunk inside the block's cooling passages. This rusts out freeze plugs from the inside and plugs up radiators. Flush the living crap out of it.
I will have to check for a thermostat when I can after work. Also it has an oldish looking napa rad cap rated at 11lbs.
#34
Originally Ford listed part number C9AZ8100A for Bumpsides. It was 13#. The current replacement part number is E5TZ8100A. Which also is 13#. Still available from your local Ford dealer. The higher the pounds of pressure the cap holds in the cooling system equals a higher coolant boiling point. But 13# is the max for older cooling systems. The newer vehicles with a cross flow radiator take 16# caps. So down flowing radiators take a 13# and cross flow radiators take a 16#.
#35
#36
So in general, I dont know how the oil got so brown. The previous, now replaced thermostat was completely stuck shut. Since Ive put a couple hundred miles on it so far going back and forth to work, driving around town, hell I even towed a friend of mine uphill to her place. It runs strong, it isnt eating oil, and its holding coolant. The only thing I noticed is if I gas it uphill the exhaust is like a noticeable grey cloud but then again the muffler and tail pipe is rotted out. Hmmph what do you guys think?
#37
#38
Its really bad, as soon as it starts going uphill the exhaust is grey and really noticeable. It looks really bad. I suspect the piston rings but whenever it starts up the oil pressure is in the high end while warming up, and then stays in the middle on the road. At least, last week it dipped down a bit but evened out after not too long.
#39
Grey smoke could be a carb problem. If it's running rich it will do that. Blue smoke is more an indication you have a ring problem. You could try a can of "stiction eliminator" from hotshot secret in it. This stuff is supposed to clean out oil residue and could clean out the ring grooves as well. Did you get your misfire cleared up too?
#40
So I'll go through the carb and take it out for a spin and see how it does. Thanks
#41
#42
#44
Hotrodhoarder
108
08-29-2014 05:25 PM
ihf-350
05-28-2012 10:12 PM
