Blown Head Gasket, Still runs.
110-124 tells us the head gaskets are not leaking. I'd run it around a bit to flush out the inside of the block then change the oil again. Especially the filter. This poor rig has been neglected that bad sounds like you better do a real good inspection. The full brake system. In the drums, rubber hoses, metal lines, M/C, etc. Repack wheel bearings. All rubber under hood. COMPLETE tune up. Etc. The whole schmeer. This way it's safer and you've got a starting point for it's new life.
Yup, always do the obvious and simple stuff first, and the routine maintenance. Was the freeze plug gone or just rusted through? Gone might mean it froze up and possible cracked the block. If it is rusted through, I would replace them all.
I also never take an old vehicle out on the road until I have at least replaced everything that's rubber in the brake system and flushed the lines.
I did do an oil change and I plan on running a bit when I get the freeze plug in. It looked like it probably rusted out, because the other ones werent popped or anything. Once the engine status has been determined I will then replace the feeder hoses and all that. Thanks so far.
Well then should I use the block as a boat anchor then? If its cracked then its just a big pos then right?
Side note, it misfires like hell but runs good and I love the old t18 in it.
Like Brian1971f100 said watch the hoses! They start going bad on the inside. The radiator takes a 11PSI cap, and the water doesn't flow real fast at idle. With all that iron, it takes a while to heat up that big engine block. But once it's warm it's like a cast iron frying pan, lots of heat everywhere.
#28
Well, that is somewhat encouraging. Now to find that miss. It's pretty simple to determine which cylinders aren't pulling their share by removing plug wires (at the cap unless you want jolted) and seeing which ones the engine sound doesn't change on. Also a simple matter to do a compression test or use a vacuum gauge when diagnosing.
#29
