88 4.9 valve adjustment
Ok so this Motor has blown a head gasket after it was supposedly rebuilt 50k ago
And I am beginning to think it was because of my valve clearances but I am not sure.
Some say since it has hyd lifters it doesn't need any adjustments at all
And the Chilton manual says the allowable clearance is 0.10-0.20 in and the desired clearance is 0.125-0.175
Now keep in mind this Motor has 580 k on it and it has been decked twice.
Now my question is am I making this a big deal is it really just that simple there is no adjustment or is the Chilton manual the correct way to go and also if it is correct where do I get shorter push rods to loosen my clearance since they are to tight because i have talked to the machine shop where it was machined and they have shorter pushrods but they are not short enough to put my clearances in spec.
I is intake
E is exhaust
Also my pushrods are all
10.14
The machine shops shortest is a
10.136
so the total under size is a 0.22
My current clearances on a 10.14 rod in firing order.
1E 0.069
1I 0.054.
5I 0.095.
5E 0.08.
3I 0.085.
3E 0.095.
6 I 0.058.
6 E 0.058.
2I 0.09.
2E 0.09.
4I 0.11.
4e 0.080
I is intake
E is exhaust
10.14
10.136
1E 0.069
1I 0.054.
5I 0.095.
5E 0.08.
3I 0.085.
3E 0.095.
6 I 0.058.
6 E 0.058.
2I 0.09.
2E 0.09.
4I 0.11.
4e 0.080
kjs5055
09-28-2016 04:02 PM
mx985
06-23-2009 11:28 PM
dano2010
07-07-2005 08:54 PM
BC/DC
04-25-2005 12:56 PM
