Torque Specifications for a 300 CI six
Anyone out there know the torque specs for the flywheel to the crank/ pressure plate to the flywheel/ also I am replacing the input and output shaft seals on a four speed transmission and I need to know the torque specs for tightening the yoke. Again, engine is a 300 cubic inch six cylinder Ford Engine. Thanks
Hi there. As far as the torque specs: the flywheel bolts are 75-85 ft. lbs. and I.m checking for the tranny specs for you. I have a complete shop manual for the 1967 ford truck and still looking for the yoke specs. I'll get back to you. If you need any other torque specs, just type away.
cadunkle
11-19-2016 06:59 PM
F-100project
08-27-2016 06:34 PM
rickgthf
10-21-2006 04:43 AM
