WONT STAY RUNNING 1997 FORD 7.3
We have replaced the idm icp under valve cover harness glow plug relay cps cleaned the regulator new fuel filter it has no blown fuses and fuel pressure is around 55 psi it runs perfect for about 5 to 10 seconds then just shuts off like turning a key i don't know what else to do
you replaced the CPS but how bout going back and looking at the connector really good. I hope u used a motorcraft cps and not cheap one.
I remember reading sometime back that if the ecm does not sense CPS run signal in several seconds, that it will cut off. I think it would run 10 seconds or so.
It must not be too big an issue since he has not been back. U are correct, it does need CPS signal to crank. I was thinking possible noise once running in signal. I also see hpop reservoir route as being viable.
The reason i suggested it was I had read it and also experienced at a show recently. Truck would crank good, run for less than 15 seconds and quit. It would do it over and over. The cap had been leaking that covers hpop gear nut. It had oiled the cps connector pretty good. We cleaned it really good with brake clean it started running fine.
sorry about not getting back sooner i use the computer at work and we are closed on weekends i have checked the hpop before i replaced the sensors i called our local ford mechanic and he walked me through checking it properly the cps was a motorcraft the ipr has been replaced as well oil is in the safe mark on the dipstick it still fires rite up for 5 to10 seconds and dies as it runs for that period of time it is a perfect smooth idol and has no check engine light
