i got my hands on a snap on solus edge reader and did a system check and i got a p code for all 8 cylinders high to low side open a p0264 cylinder 2 injector circuit low and p1294 high side open bank #2
i got the codes cleared buzz test showed nothing was wrong with the truck i was able to get it running long enough to plug the snap on reader in and i found the icp voltage was at 0.02 volts even at 2000 rpm and didn't change at any rpm the sensor is a new motorcraft connector wires are perfect no oil in or on the connector wires are good all the way to the main harness
