Custom Aluminum 80 gallon Fuel Cell w/Sump
Can anybody tell me who can make a Custom Aluminum 80 gallon Fuel Cell w/Sump, The 80 gallon Fuel Cell is based upon (4) 20 gallon Fuel Cells, Here’s the Dimensions for the 80 gallon Fuel Cell w/Sump, The Dimensions are (L):48"x (W):40"x (D):10".I've contacted RCI and they'd told me anything over 20 gallon has to be a steel tank.I've also contacted JAZ Products & Fuel Safe and hadn't heard from either one on the Custom Aluminum 80 gallon Fuel Cell w/Sump.
BroncoDually
BroncoDually
I built a couple of 20 gallon cells out of aluminum in the past, and anything over that, I wouldn't go the normal route.
The dims you list come out to 83 gallons and 498 pounds. I personally would use steel too. That's a LOT of weight sloshing back and forth.
If you do find someone to do it, I would use at least 3/16" with a lot of extra supports in the corners and along the sides, and baffles. Also, welding both the inside and outside of the corners.
Why not stainless?
Why not stainless?
Custom Custom Aluminum 80 gallon Fuel Cell w/Sump
81ChopTop,The Custom Aluminum 80 gallon Fuel Cell w/Sump is based upon (4) RCI 20 gallon Pro Street Fuel Cells,The Dimnsions for the (4) RCI 20 gallon Pro Street Fuel Cells are:
(L):24" (x2)-(48")
(W):20" (X2)-(40")
(D):10"
Sorry I'd forgot 2 mention where I'd came up with the formentioned dimensions
(L):24" (x2)-(48")
(W):20" (X2)-(40")
(D):10"
lucaslaw
08-12-2009 10:24 AM
dfmatt
Bio-diesel, Propane & Alternative Diesel Engine Fuels
07-05-2008 08:44 PM
