My power stroke was running great but didn't start up after I turned it off. I changed the fuel filter and I changed the starter. I got her running again but it was showing low pressure on the gauge and when you push the gas pedal it drops. Any ideas?
this type of engine when it runs out of oil will loose injector pressure before bearing damage will happen, unless you are coasting down a long hill with no oil in it
