carburator problem?
Old Sep 1, 2003 | 12:29 PM
JohnMartin@Frontiernet.ne's Avatar
carburator problem?
Hi.
I have a 351 W motor in a F-250. Could anyone tell me a replacement carburator? All of the polluction stuff has been previously removed and I am looking for an easy install without all the pollution crap.
JEM
Old Sep 5, 2003 | 05:25 PM
f100guy's Avatar
f100guy
carburator problem?
do you mean an aftermarket carb? if it is 2 bbl. then holley makes a nice 500 cfm carb but if it is 4 bbl. or you want to spend some extra cash to get another intake edelbrock has a 650 carb for 250 model # 1406 i have that one it is nice and it work great as long as you take care of it
Old Sep 6, 2003 | 08:47 AM
carburator problem?
what about the install do you have to modify anything?
Old Sep 6, 2003 | 10:00 AM
f100guy's Avatar
f100guy
carburator problem?
no
just a new carb gasket or intake gasket if you want to change intakes
Old Sep 12, 2003 | 09:27 PM
diztbone's Avatar
diztbone
carburator problem?
Just to make certain.... I have an '86 F-150 with a Holley 4bbl. They carb has to go...or be remanned. I would like to put an Edelbrock 1406 600 cfm on instead of another Holley. In addition to the tranny kicker, do I also have to change the intake man?
Old Sep 12, 2003 | 09:57 PM
f100guy's Avatar
f100guy
carburator problem?
it depends on if your carb is a spreadbore or not but they make adapters to make it fit
Old Sep 13, 2003 | 02:23 AM
864604X4's Avatar
864604X4
carburator problem?
I've had good luck with both Holley's and Carter's. A 625 Carter AFB with electric chock would be nice carb. If you have a auto you need one with the ford kickdown. Check out Summit Racing. If your truck is a 4 barrel. I thought those years were, My 460 is.
Scott
Old Sep 13, 2003 | 03:55 PM
diztbone's Avatar
diztbone
carburator problem?
Thanks guys. I'll proceed, but be prepared for the ever required extra trips to the parts store.
M
