borg warner 13-56
Old 12-04-2001, 06:04 PM
orange peel
orange peel is offline
orange peel is starting off with a positive reputation.
borg warner 13-56
i have the borg warner 13-56 t-case on my '87 f-150, i would like some info on this t-case, stuff like how strong it is etc. i would also like to know what is a stronger t-case to replavce it with if the 13-56 isnt strong enough somethin like a np205 or somethin. thank you for your help.
Old 12-04-2001, 07:11 PM
Pastmaster
Pastmaster is offline
Pastmaster is starting off with a positive reputation.
borg warner 13-56
It's chain driven, and moderately tough. I haven't heard of any one having trouble with them in F-150's, even with lifts and alot of 4x4 use.
If you flush the fluid it should give lots of years of life.
'93 F-150 loaded and modified!
Several other project vehicles
Old 12-04-2001, 07:28 PM
orange peel
borg warner 13-56
the 13-56 is not chain driven, i have a haines manual and the diagram shows that it is all dears that and my freind has a np208 on his measly k5 and it is chain driven and is much samaller than my 13-56
Old 12-04-2001, 07:58 PM
mrlaserboy
mrlaserboy is offline
mrlaserboy is starting off with a positive reputation.
borg warner 13-56
[updated:LAST EDITED ON 04-Dec-01 AT 09:04 PM (EST)]The 1356 IS chain-driven, as well as the 208 and the 1354. The 205 is gear driven and I think the 203 is as well.
Anyways, the 1356 is a good t-case and was offered in the 1-ton trucks behind 460's and diesels. I haven't had any problems with both of my 1356 t-cases, one of them has 210K miles on it.
Here's a pic of the inside of a 1356 with a slip-shaft rear output-
http://www.medicine.wisc.edu/~mrm/bronco/1356shaft/1356rear_cover.gif
Old 12-04-2001, 09:39 PM
madman666's Avatar
madman666
madman666 is offline
madman666 is starting off with a positive reputation.
borg warner 13-56
[updated:LAST EDITED ON 04-Dec-01 AT 10:43 PM (EST)]Visit these web sites they have some information your looking for.
http://www.technicalevolution.com/borg1356.htm
http://www.jeepland.net/tcase.shtml
Old 12-04-2001, 10:45 PM
Pastmaster
borg warner 13-56
Take a look on 7C-5 of the Haynes number (53). Chain drive!
Old 12-05-2001, 12:13 AM
ddestruel
ddestruel is offline
ddestruel is starting off with a positive reputation.
borg warner 13-56
[updated:LAST EDITED ON 05-Dec-01 AT 01:20 AM (EST)]The BW1354, BW1356, NP208, full time NP203 and all newer NV t-cases are chain driven the NP 205 is a gear drive. The last gear drive t-case in a domestic truck was 1993 when dodge discontinued the use of the NP 205 behind thier diesels and the GM made Getreg 360 five speed. biggest problem with 1356's is the pump failing or cloging, buring up the insides otherwise they last quite awhile. They do hold up to the diesels, so that must say something. there are several variations of the 1356 depending on the size of the vehicle and engine. for example 1 tons have pto plates so the housing is larger. The out put spline count on a ford tranny and the six bolt 360* pattern is compatible with any NV truck tranny, if you want tough and 2.01 or better:1 lower low range look around in the yards for a NV chain drive t-case in a dodge 3/4 ton or 1 ton made from 94 on. if you want a 2:1 low range and bullet proof look for an earlier ford NP 205 t-case with a cst iron housing identifible by the little three bolt circular plate in the center of the back of the housing a housing which visually is very similar to a chain driven full time 203 which lasks the three bolt center plate. be sure what ever you find has the driver side out put for the front drive line.
Hope these little tid bits help.
Dusty
Old 12-05-2001, 03:15 AM
brett_d
brett_d is offline
brett_d is starting off with a positive reputation.
borg warner 13-56
tilopa
12-03-2013 01:44 PM
aaroncmears
07-02-2013 10:20 PM
dig'umz
02-18-2013 10:50 PM
aurgathor
Oil & Lubrication
01-16-2005 12:50 PM
str8six
12-27-2002 09:38 AM
Quick Reply: borg warner 13-56
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
