1989 F150 Long Tube Headers
I just wanted to clear the air. I did quite a bit of research prior to going for it, but I decided that if i was going to go for headers, i would do long tubes. But, long story short, THEY FIT. I read tons of posts everywhere that long tube headers don't fit, and there was one person (not sure where, and I'm sure I can't find the post) who said they did fit. But I have an 89 302 with a 4 speed manual with granny, and they fit. Albeit I've been a tech for years and I have a welder and cutting tools all over the place, but it's doable. If you're looking for a direct fit, maybe not. You have to bend a 90 degree off the drivers side header and be creative to get it over and past the trans and cross member with a little welding, but the headers and exhaust do fit if done properly. Working on a true duals setup. Pics to follow.
All right! I'd like to know which ones you used as well. Looking forward to the pics! I'm hoping to use cheap ones, like less than $200, and get em jet-hotted. I'm in OK, so why not... Then, hopefully I can weld the rest of the pipes myself. The exhaust system is about gone to rust, anyway, so instead of replacing I'm upgrading.
I clamped in case I ever need to pull the transmission. The drivers side clears the slave. Very very minor frame trimming on right side. It cleared but only by 1/32. I trimmed to give clearance so the engine torquing back and forth didn't hit
I used flowtech long tubes. Available at an advance near you. They are cheap and don't look bad. I painted them prior to install because they are only steel.
Sorry for the long delay. Forgot I posted this, but I'll try to get some photos shortly.
FarmerJayBird
01-30-2011 11:23 PM
greenmachinejohn
02-22-2009 11:47 AM
cscott952
03-04-2008 11:28 AM
91Blues
12-28-2005 08:33 PM
