The Price of Bronco's Lately - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
  #31
Old 02-07-2018, 08:21 AM
Tim Hodgson's Avatar
Tim Hodgson
Tim Hodgson is online now
Learning slowly...
Tim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to behold
Originally Posted by Bruners4 View Post
Check the rear brake light bulbs to make sure that they are NOT LED bulbs.
Curious. Why?
  #32
Old 02-07-2018, 12:02 PM
45FMJoe
45FMJoe is offline
45FMJoe is starting off with a positive reputation.
On the OBS trucks the transmission/cruise control and brake light circuit is all in one. If you try to put LED bulbs in the taillights, there isn't enough resistance in the line and it screws with everything. One symptom is the torque converter will unlock when you tap the brakes. The fix is to solder resistors in line before the taillight sockets. I don't want to hack up the wiring on my '95 F-250 so my brake lights aren't LED. The older trucks don't have this problem so my '79 Bronco will have LEDs all around.
  #33
Old 02-07-2018, 12:15 PM
McLeod's Avatar
McLeod
McLeod is offline
McLeod has a good reputation on FTE.McLeod has a good reputation on FTE.
How come so many people want to do LEDs instead of just using the original style light bulbs?
  #34
Old 02-07-2018, 01:38 PM
Tim Hodgson
Learning slowly...
45FMJoe: Reps sent!
Your information on the transmission/cruise control and brake light circuit deserves its own thread !!! Thank you for your contribution(s) buddy!
  #35
Old 02-07-2018, 04:36 PM
45FMJoe
45FMJoe is offline
Originally Posted by Tim Hodgson View Post
45FMJoe: Reps sent!
No problem! I actually just bought the F-250 a couple months ago so I'm still learning all about the OBS trucks but I've always loved the body style. I will say this, get rid of the yellow dome light cover for the clear one Broncograveyard sells and swap in an LED bulb, the difference is night and day. LEDs are safe to use in everything except the brake light circuit. You need an electronic flasher to use LEDs in your turn signals and in the gauge cluster you can't use LED for the brake warning lights or 4x4 indicator lights. Everything else is good to go, though.
  #36
Old 02-07-2018, 05:41 PM
Tim Hodgson
Learning slowly...
45FMJoe: OK Mr. light guy, what should I do to get my headlight low beams on with my high beams when I have 9007 halogen dual filament single bulbs? See below:
https://www.ford-trucks.com/forums/1...tune-up-2.html
I am about to buy a Corolla replacement headlight assembly and cut off the lens and glue the dual bulb projector bulb holders to the back of oem '95 Bronco/F150 diffuser lenses to get both on at the same time...
  #37
Old 02-08-2018, 08:56 AM
Redark1
Redark1 is offline
Redark1 is starting off with a positive reputation.
if your using the relay kit for the headlights then it should only take adding a jumper wire to one of the relays or adding another relay.
this is the relay kit for the early ones but it says it uses a diode to get both to turn on at the same time. don't know if it would fit but would be worth a call. hth
https://www.tomsbroncoparts.com/prod...ord-bronco-new
  #38
Old 02-08-2018, 11:04 AM
Tim Hodgson
Learning slowly...
  #39
Old 02-08-2018, 12:23 PM
OldGrayMare's Avatar
OldGrayMare
OldGrayMare is offline
OldGrayMare is gaining momentum as a positive member of FTE.
Always get asked what would it take to sell mine, have no idea what to price it at. Any suggestions ? 88 xlt, 33's with 3" lift, only rust is starting in the normal tailgate area. Cloth interior with dual arms captains seats, nice stero, 302 / aod, 90,000 miles, cruise, elec windows and locks, bought it 11 years ago and it's been my daily driver.
  #40
Old 02-12-2018, 06:54 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
There is a 93 EB on cl here listed for $20,000 and a couple other models $12-15K. The only sub-$1000 are missing engines. What they're asking and what they actually get is another story...
Wayford
12-08-2017 11:55 AM
Johnny Mayday
12-03-2017 12:52 AM
street rodder
06-14-2017 07:15 PM
robbie42301
01-04-2017 11:46 AM
lafermedavid
09-30-2016 05:08 PM
Quick Reply: The Price of Bronco's Lately
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
