What are these in the engine bay?
OP plan on having one hell of a time removing the distributor, plugging the hole and then trying to drill the hold down bolt and easy out it out.
GOOD LUCK
I'll stick a zip tie end down and see how far it goes. Everything else snaps off this block so I wouldn't be surprised. I have a good running but non roller 93 engine in the garage looking a lot better if that bolt is snapped. I can convert it to roller with jy parts. But I wouldn't swap the 94 cam in so, next question.
Speed density roller cams that work with 1.7 roller rockers, or the same with 1.6 roller rockers(set for $60 locally)? Rest of the plans include gt40p's, long tubes, and if the money is right, typhoon intake. Pretty much the standard upgrade around here it seems. Just want to wake it up, not set any records.
on
If I was to toy with deleting the EGR at some point, what I would like to do is sandwich a plate between the valve and intake, plug the vac lines, and leave the electronics in place. From what I've read, I thought that would leave me with no blinding CEL. But from what you just said, it seems like that may not be the case, unless in doing what I mentioned, the signal to open never happens anymore.
I welded an EGR bung on a set like that once.. worked great.
Paul, I misspoke twice. I want to leave the vac lines hooked up to the EGR and its solenoid, if I "disable" the EGR. And I wanted to do a trial run, pre upgrades to see if there were any ill effects. If I have a problem, all I'd have to do would be to remove the sandwiched plate between EGR and intake.
I may need clarification again on using EGR with the typhoon intake if I ever get there...
Everyone, just past my line of sight from the ground, and not really visible in the pic with dizzy, about a quarter inch into that hole, it sure does seem like a snapped off bolt lives there. Still haven't had a great look but I'm wondering how long the bolt is, if anyone has had one off in recent memory. The spare engine is tucked behind some other projects for the time being. Also thinking I'm glad I have a Hyundai with a 20 year warranty.
