73 f250 camper special light switch issue
Pulled the dash to replace a bad wiper switch and decided to replace the light switch at the same time. Start the truck no lights, just fine turn the light on then off and parking lights won't turn off? I have to disconnect the battery and start again to turn parking lights off. Bad switch?
Thats got to be a bad switch. Assuming you didnt damage the harness end of things Id return that and get another. Curious if your having the "lights out" issue I once had on my 68 F250. Overhead camper, lots of lights, bad grounds causing the headlight switch that has a breaker built into it to over heat and kill the lights intermittently. Pucker factor!!
Southern Comfort
03-29-2013 10:24 AM
dyoungen
01-08-2008 07:55 PM
