Manual transmission oil change
The sticker on the door has codes on it 1 being a trany code.
Go to Gary's site and find the certification label decode to see what the truck came with.
Get under and check to see if the trany has a plate bolted on the side for a PTO.
Can you post up a picture of the shift lever and I can match it up to either one of mine
and tell you what you have.
Dave ----
3sp OD
4sp with granny low
A few ways to tell.
Dave ----
Dave ----
A few ways to tell.
Dave ----
3sp OD
4sp with granny low
Dave ----
3sp OD
4sp with granny low
thanks Dave sounds good. I still got a gallon of gear oil left so I'll just drive it for a while and change it again!
WI1983F250
12-06-2014 04:30 PM
kwe45919
60
09-14-2014 09:20 PM
FoPar1972
19
02-15-2012 11:37 PM
