Injectors
  #121
Old 02-22-2018, 07:31 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Gasket is reusable and stays in place you'll see how it works when you open it up.
  #122
Old 02-22-2018, 07:36 AM
Sous's Avatar
Sous
Sous is online now
Received 4,428 Likes on 2,835 Posts
The gaskets and harnesses are re-usable as long as they are in good condition.
I have never done it, but as I understand it the engine is started and left to idle or fast idle to operating temperature with the following parts removed from the truck.
1. Valve covers
2. CAC tubes
3. Intake tube
Everything else is connected. Ensure that no tools, rags or debris are near the engine when it is warming up.
  #123
Old 02-22-2018, 07:45 AM
MTP55's Avatar
MTP55
MTP55 is offline
Alright. Thanks.
  #124
Old 02-22-2018, 07:59 AM
andym's Avatar
andym
andym is offline
Originally Posted by MTP55
I might finally have a chance to pull my truck in. If I take valve covers off, do I need to replace the gasket? Also, it may be a stupid question, but how do people run the truck with the valve covers off if the wiring harness is attached to it?
Replacing the gasket isn't necessary as long as it doesn't leak oil, none of the connectors are burned or melted, and all the plugs and injector solenoids ohm out properly.
The 42-pin harness is not actually connected to the valve cover.
  #125
Old 02-22-2018, 08:17 AM
MTP55's Avatar
MTP55
MTP55 is offline
Oh ok. Someone told me that it's molded into the valve cover. I didn't think that made sense but stranger things have happened.
  #126
Old 02-22-2018, 08:38 AM
andym's Avatar
andym
andym is offline
The wiring for the glow plugs and injector solenoids are molded into the valve cover gasket. Perhaps that's what they were talking about.
  #127
Old 02-23-2018, 08:55 AM
MTP55's Avatar
MTP55
MTP55 is offline
Do the CAC tubes have to be completely removed or just undone on the topside?
  #128
Old 02-23-2018, 12:05 PM
brian42's Avatar
brian42
brian42 is offline
It's not molded but there is a bracket that supports the connector. You have to remove the bracket (it's on the driver's side) to get the valve covers off. This bracket is what the 42-pin connector mounts to.
You m-i-g-h-t be able to get the driver's side valve cover off by loosening the clamps on the driver's side and only removing the spider connection but I've never done it. There's no way you'll get the passenger's side cover off without removing the CAC tube. Even with removing the oil filler tube (check the o-ring if you do to see how swollen it is...you might want to spend a couple of bucks for a new one) it takes some maneuvering. If you loosen the A/C bracket and let it hang forward a little bit that helps but I've not done that. I have a lower alternator and that additional bracket complicates anything I do on that side (valve covers, EBP tube).
  #129
Old 02-23-2018, 04:41 PM
MTP55's Avatar
MTP55
MTP55 is offline
Are the CAC tubes what people complain about being a nightmare to reinstall or are they talking about something else?
  #130
Old 02-23-2018, 04:51 PM
Sous's Avatar
Sous
Sous is online now
You might be thinking of the up-pipes, baby butt and turbo lining up issue. The CAC tubes are really quite easy. Sometimes I have to fight with the spider boot on the drivers side, but it is not hard at all.
  #131
Old 02-23-2018, 04:52 PM
MTP55's Avatar
MTP55
MTP55 is offline
That's does ring a bell. Thanks.
  #132
Old 02-27-2018, 07:00 PM
MTP55's Avatar
MTP55
MTP55 is offline
Alright, didn't get to do this the last week or so because I got a bad cold or something. Is there any reason to not clean things before I take the covers off with brake cleaner? That's normally what we use here but we normally work on machinery without wires and other fun stuff. I've heard of people using mean green or some such.
  #133
Old 02-27-2018, 07:10 PM
Wes444's Avatar
Wes444
Wes444 is offline
Received 1,131 Likes on 643 Posts
It's way easier to clean the valve covers with them off. It's Simple Green that everyone here loves. Me included. Old toothbrush and a coupe rolls of paper towels, good tunes n a touch of patience
  #134
Old 02-27-2018, 08:18 PM
MTP55's Avatar
MTP55
MTP55 is offline
Gotcha. I was halfway there. I'll give the covers and tubes a good cleaning while I have them removed. Thanks!
  #135
Old 02-27-2018, 08:46 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
I would clean up around edges of valve covers & any big accumulation that might fall in to valve train during removal,I always keep air blower handy to quickly dry brake clean around sensitive wire/components.
Quick Reply: Injectors
